How to read logs with javascript - Printable Version
+--- Thread: How to read logs with javascript (/showthread.php?tid=774)
How to read logs with javascript - Mirco - 05.05.2017
Hi guys,
I would like to read from logs: data, time, group address and value.
I want to use an iFrame with an HTML page that display those datas as the customer wants Wink
RE: How to read logs with javascript - Mirco - 09.05.2017
Nobody can help me?? Confused
RE: How to read logs with javascript - buuuudzik - 09.05.2017
You should prepare .lp file in/user/ location(e.g. logs.lp) and inside you must prepare in lua such script:
<? -- How much objects do you need? objects_number = 10 query = "SELECT ol.logtime, o.name, ol.datahex, o.datatype, ol.eventtype FROM objectlog AS ol, objects AS o WHERE ol.address=o.address AND ol.eventtype IN ('write', 'response') ORDER BY ol.logtime DESC LIMIT " .. objects_number result = db:getall(query) logs = {} for _,row in ipairs(result) do       logs[_] = {logtime = os.date('%Y.%m.%d %H:%M:%S', row.logtime), name = row.name, value = knxdatatype.decode(row.datahex, row.datatype)} end logs = json.encode(logs) print(logs) ?>
And when you will have this file you can use it in js by:
$.get( "/user/logs.lp", function( data ) {    res = data.trim();    res = JSON.parse(res); // further operating with data in javascript ;)  };
Or maybe better for you would be to prepare all html, js and lua in this .lp file Wink
RE: How to read logs with javascript - Mirco - 16.05.2017
Thank you buuuudzik! Big Grin
RE: How to read logs with javascript - buuuudzik - 16.05.2017
You're welcome and good luck with your projectWink
