[OLD] LogicMachine firmware 2015.09.17 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: Announcements (https://forum.logicmachine.net/forumdisplay.php?fid=7) +--- Forum: Software updates (https://forum.logicmachine.net/forumdisplay.php?fid=13) +--- Thread: [OLD] LogicMachine firmware 2015.09.17 (/showthread.php?tid=78) |
[OLD] LogicMachine firmware 2015.09.17 - admin - 23.09.2015 LM Reactor V2: https://dl.openrb.com/lm-15.09/reactorv2.img LM Reactor: https://dl.openrb.com/lm-15.09/reactor.img LM Reactor Lite: https://dl.openrb.com/lm-15.09/rctl.img LM4: https://dl.openrb.com/lm-15.09/lm4.img LM3 V2 (3 x RS-485 and 1 x RS-232): https://dl.openrb.com/lm-15.09/lm3v2.img LM3 V1 (4 x RS-485): https://dl.openrb.com/lm-15.09/lm3v1.img LM2 (All models): https://dl.openrb.com/lm-15.09/lm2-at91.img RE: [RELEASE] LogicMachine firmware 2015.09.17 - George - 24.09.2015 (23.09.2015, 08:51)admin Wrote: LM Reactor V2: https://dl.openrb.com/lm-15.09/reactorv2.img Edgards, Could you please detail How to check the exact version your working with ? Thanks, Joris RE: [RELEASE] LogicMachine firmware 2015.09.17 - admin - 24.09.2015 In Logic Machine interface check left bottom corner, it will display the current version that your device is running. RE: [RELEASE] LogicMachine firmware 2015.09.17 - rocfusion - 25.09.2015 Hi, Is there release note available to see whats new \ fixed? Thanks, Roger RE: [RELEASE] LogicMachine firmware 2015.09.17 - admin - 25.09.2015 The main new feature is the addition of Apps. Apart from that it's mostly a maintenance release with some minor bug fixes. RE: [RELEASE] LogicMachine firmware 2015.09.17 - Peter - 25.09.2015 Can you please release some info how to write, share and possibly sell our own apps? Thanks RE: [RELEASE] LogicMachine firmware 2015.09.17 - admin - 25.09.2015 Full tutorials will be provided later on. All Apps are free for now and are published by sending application files to us. Apps are written in JavaScript/HTML/CSS on client side and Lua on server side. Please find attached short documentation on Apps and sample application. Upload sample folder to data directory by using FTP with username apps (you have to enabled FTP and set password in System config first). After that you will have sample application visible on the main screen. RE: [RELEASE] LogicMachine firmware 2015.09.17 - Peter - 25.09.2015 thank you RE: [RELEASE] LogicMachine firmware 2015.09.17 - kostou - 21.10.2015 Ηι I have a Logic machine 2 version Flash sys v2 r89 (05-10-12) is compatible with the version lm-15.09 / lm2-at91.img? Τhanks, Kostas RE: [RELEASE] LogicMachine firmware 2015.09.17 - admin - 21.10.2015 Quote:I have a Logic machine 2 version Flash sys v2 r89 (05-10-12) is compatible with the version lm-15.09 / lm2-at91.img?It should work, but don't forget to make a full backup before upgrading. There might be some minor issues with visualization after the upgrade, everything else should work well. RE: [RELEASE] LogicMachine firmware 2015.09.17 - andeug - 02.04.2016 Hi, I have not seen any updates regarding the LM4 software. Will it come a new release soon? Currently I have the version 2015.09. Regards, Andreas RE: [RELEASE] LogicMachine firmware 2015.09.17 - admin - 04.04.2016 We're finishing the last testing phase, new release should be out very soon
RE: [RELEASE] LogicMachine firmware 2015.09.17 - KingCanute - 29.04.2016 (04.04.2016, 08:34)admin Wrote: We're finishing the last testing phase, new release should be out very soon Any estimated release date for the new firmware? It's soon 4 weeks since you said very soon
RE: [RELEASE] LogicMachine firmware 2015.09.17 - andeug - 24.05.2016 @KingCanute: I guess that this was the topic you were looking for: http://forum.logicmachine.net/showthread.php?tid=292 |
