Bus monitor in ETS through LM - Printable Version
+--- Thread: Bus monitor in ETS through LM (/showthread.php?tid=786)
Bus monitor in ETS through LM - bmodeco - 16.05.2017
I am using the LM5 to program my KNX-devices through ETS-software which works as expected.
When using the monitoring in ETS I only get info when using the group-monitor: it shows all group adresses being triggered realtime.
However when I use the bus-monitor nothing shows up? Is this normal behaviour? Or do I need to change a setting in LM to do this.
Thansk, Bart
RE: Bus monitor in ETS through LM - admin - 16.05.2017
Bus monitor is not supported
RE: Bus monitor in ETS through LM - bmodeco - 16.05.2017
(16.05.2017, 07:21)admin Wrote: Bus monitor is not supported
Hi admin,
thanks for your quick response - did some googling: need a separate IP interface to do this.
Best regards, Bart
RE: Bus monitor in ETS through LM - Thomas - 05.11.2021
Is there some way how to get bus monitor running? Newer firmware or settings?
Or maybe there's a better way. I'm looking for source of TP repeats. It's not critical but I'm getting 10 repeats per hour. Is it possible to investigate it through LM?
Thank you
RE: Bus monitor in ETS through LM - Daniel - 05.11.2021
Nothing has changed, only group monitor will work.
RE: Bus monitor in ETS through LM - admin - 05.11.2021
Try enabling "ACK all group telegrams" and see if it makes a difference on the number of repeats.
RE: Bus monitor in ETS through LM - JRP - 07.11.2021
If an IP interface is used, the bus monitor does not work even in the ETS.
Greetings
RE: Bus monitor in ETS through LM - Daniel - 08.11.2021
You probably creating KNX loop with your interface.
