Use Lm3 to control your Yamaha Receiver using HTTP commands ( RX- V671) - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Use Lm3 to control your Yamaha Receiver using HTTP commands ( RX- V671) (/showthread.php?tid=793) |
Use Lm3 to control your Yamaha Receiver using HTTP commands ( RX- V671) - phongvucba - 17.05.2017 Help me! I have information about a device that can connect to control it via HTTP. I want to control the Yamaha RX-V671 through Lm3. Has anyone ever done it, or who can write a script to do it. Help me, I am very thankful! I am new to Lm3! Should not be very understanding. Https://github.com/a-lurker/Vera-Plugin-Yamaha-RX-HTTP ----------------- https://www.google.com.vn/search?q=V671_3071_FuncTree_1.10.xls&oq=V671_3071_FuncTree_1.10.xls&aqs=chrome..69i57.530j0j4&sourceid=chrome&ie=UTF-8 https://forums.homeseer.com/showthread.php?t=157837 Can you write a script to turn off or turn on the player via Lm3? Select HDMI 1, Select Audio 1 Thank so much! RE: Use Lm3 to control your Yamaha Receiver using HTTP commands ( RX- V671) - Magnus Lindgren - 17.05.2017 Maybe this? I made this script to mute my receiver when i go out: Code: http = require("socket.http")
url_string = "http://192.168.0.43:80/YamahaRemoteControl/ctrl"
http.TIMEOUT = 5
value = event.getvalue()
if (value == false) then
post_request_body ='<?xml version="1.0" encoding="UTF-8"?><YAMAHA_AV cmd="PUT"><Main_Zone><Volume><Mute>Off</Mute></Volume></Main_Zone></YAMAHA_AV>'
elseif (value == true) then
post_request_body ='<?xml version="1.0" encoding="UTF-8"?><YAMAHA_AV cmd="PUT"><Main_Zone><Volume><Mute>On</Mute></Volume></Main_Zone></YAMAHA_AV>'
http.request(url_string, post_request_body)Just change IP to your receiver and put the script in a event. RE: Use Lm3 to control your Yamaha Receiver using HTTP commands ( RX- V671) - eilert - 26.01.2022 (17.05.2017, 15:51)Magnus Lindgren Wrote: Maybe this? I made this script to mute my receiver when i go out: If someone is interested, I found out that more recent Yamaha receivers use this protocol; https://www.sdu.se/pub/yamaha/yamaha-ynca-receivers-protocol.pdf TCPIP port should be 50000 A power on command would look like this: Code: post_request_body ='<?xml version="1.0" encoding="UTF-8"?><YAMAHA_AV cmd="PUT">@MAIN:PWR=On\r\n</YAMAHA_AV>'Best regards Eilert Bjerkan |
