Vis. elements order (z-axis) - Printable Version
+--- Thread: Vis. elements order (z-axis) (/showthread.php?tid=800)
Vis. elements order (z-axis) - leonidas - 22.05.2017
I have some problems with visualization when I want to place one image on another (or button on button). I can't choose which image will be in front and which will be in the background. As I noticed, usually smaller image hides below larger. How this z-axis priority is made?
Tried to solve this with CSS z-index but it didn't work.
Leonidas.
RE: Vis. elements order (z-axis) - admin - 22.05.2017
Order for elements of the same type is not defined, you can set it via CSS though:
http://forum.logicmachine.net/showthread.php?tid=348&pid=1709#pid1709
