[OLD] LogicMachine firmware 2017.06 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: Announcements (https://forum.logicmachine.net/forumdisplay.php?fid=7) +--- Forum: Software updates (https://forum.logicmachine.net/forumdisplay.php?fid=13) +--- Thread: [OLD] LogicMachine firmware 2017.06 (/showthread.php?tid=823) |
[OLD] LogicMachine firmware 2017.06 - admin - 01.06.2017 RC3 is ready for testing, this is a bug-fix releases with minor changes: 1. Apps installation issue fixed 2. Object log now works properly when log policy is set to "all" and bus sniffer is disabled LM2 IMX: https://dl.openrb.com/lm-17/lm2i-20170601.img LM3 V1 (4 x RS-485): https://dl.openrb.com/lm-17/lm3v1-20170601.img LM3 V2 (3 x RS-485 and 1 x RS-232): https://dl.openrb.com/lm-17/lm3v2-20170601.img LM4: https://dl.openrb.com/lm-17/lm4-20170601.img LM5 lite: https://dl.openrb.com/lm-17/lm5m3-20170601.img LM5 lite with extensions: https://dl.openrb.com/lm-17/lm5m3ex-20170601.img LM5 4 DIN units: https://dl.openrb.com/lm-17/lm5m4-20170601.img LM Ambient: https://dl.openrb.com/lm-17/lmwall-20170601.img LM Reactor Lite: https://dl.openrb.com/lm-17/rctl-20170601.img LM Reactor V1: https://dl.openrb.com/lm-17/reactor-20170601.img LM Reactor V2: https://dl.openrb.com/lm-17/reactorv2-20170601.img LM Reactor V3: https://dl.openrb.com/lm-17/reactorv3-20170601.img Extra packages: https://dl.openrb.com/lm-17/pkg LM5 Power devices Note: if upgrade does not work, run this script once: https://gist.github.com/jsopenrb/4ba040d83cd25d51bf70a0dbc6b74447 LM5 lite: https://dl.openrb.com/lm-17-imx6/lm5m3-20170601.img LM5 lite with extensions: https://dl.openrb.com/lm-17-imx6/lm5m3ex-20170601.img LM5 4 DIN units: https://dl.openrb.com/lm-17-imx6/lm5m4-20170601.img Extra packages: https://dl.openrb.com/lm-17-imx6/pkg Load balancer: https://dl.openrb.com/lm-17/lb-20170601.img Old LM2: https://dl.openrb.com/lm-17/lm2-at91-20170601.img RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - buuuudzik - 01.06.2017 Unfortunately, almost whole was good after upgrade but unfortunately now I can't reach my LM Load Balancer
RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - admin - 01.06.2017 Can you check if it's reachable via SSH? If yes, then send me remote access to port 22 via PM. RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - buuuudzik - 01.06.2017 (01.06.2017, 13:47)admin Wrote: Can you check if it's reachable via SSH? If yes, then send me remote access to port 22 via PM. How can I check this? Via Total Commander? RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - admin - 01.06.2017 Use putty or kitty app, can you even ping the device? RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - buuuudzik - 01.06.2017 No, unfortunately I can't ping and also I can't reach it via Putty(I have tried also with working LM4 and on it is ok). I've tried also reboot a device and still the same. RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - admin - 01.06.2017 You can try running Ubuntu live USB, then I can connect through TeamViewer there. If I remember correctly you need to press F12 or Esc during start-up to select boot device. RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - buuuudzik - 01.06.2017 (01.06.2017, 15:02)admin Wrote: You can try running Ubuntu live USB, then I can connect through TeamViewer there. If I remember correctly you need to press F12 or Esc during start-up to select boot device. which kind of ubuntu? Can be from here, for desktop? https://www.ubuntu.com/download RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - admin - 01.06.2017 Try 17.04 i386 version, here's a guide on how to run it without installation: https://www.ubuntu.com/download/desktop/try-ubuntu-before-you-install RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - buuuudzik - 01.06.2017 Ok so today I will download this file and prepare ubuntu usb and if this would be not a problem tomorrow morning when I will on the installation I will contact with you. Thanks for upgrade and thanks for help
RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - buuuudzik - 02.06.2017 When I connected the monitor to Load Balancer I have such info: "Booting 'OS' RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - admin - 02.06.2017 This means that it's trying to boot, but if the main filesystem got damaged you won't see any messages. Have you tried running live USB? RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - andeug - 04.06.2017 I've upgraded to the version 20170601. Sonos app works normally, the same Mosaic and the other plugins/apps. Many thanks to Edgars and Erwin which they have fixed remotely the Sonos app on my LM4! :-) RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - jetsetter - 09.06.2017 Hi, here are my findings so far (one day) after restoring my backup to a fresh LM4 running RC3:
Also, is there a way now in RC3 to enable or disable a schedule from within a script? Thanks RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - admin - 09.06.2017 1. Schedulers conversion procedure for new HW: If an old event is set to run on both weekdays and holidays two events will be created: one that runs on weekdays, another that runs on all days and is set to run only on holidays. 2. Can you provide a backup to reproduce this issue? 3., 4., 5. This should be reported in Application Store section ![]() Scheduler API is not yet included. RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - rocfusion - 11.06.2017 Hi, Whether I use scripting or object tab interface. Create an object, that is 2 byte float or 2 byte temperature. Now try to set the value to 100 either in script or set parameter, you see 100.00. Now set the value to 101. Its new value 100.96. Any value above 100 will always round down to 0.96 Thanks, Roger RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - admin - 12.06.2017 This data type has limited precision and it gets worse for large values. For values around 100 precision is 0.08. So you can either get 100.96 or 101.04, but not 101. RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - rocfusion - 14.06.2017 (12.06.2017, 06:16)admin Wrote: This data type has limited precision and it gets worse for large values. For values around 100 precision is 0.08. So you can either get 100.96 or 101.04, but not 101. That kind of sucks. I have created a driver talking over IP which receives a temperature. when I have to update the ip device, I would have to round the value up the object value before sending. Hi, Since updating to RC3, the system log is repeating itself with the following, is this really necessary? Jun 14 05:11:08 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 14 04:41:06 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 14 04:11:06 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 14 03:41:04 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 14 03:11:03 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 14 02:41:02 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 14 02:11:00 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 14 01:41:00 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 14 01:10:58 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 14 00:40:57 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 14 00:10:57 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 23:40:55 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 23:10:55 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 22:40:53 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 22:10:52 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 21:40:52 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 21:10:50 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 20:40:50 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 20:10:48 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 19:40:47 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 19:10:47 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 18:40:45 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 18:10:44 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 17:40:43 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 17:10:41 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 16:40:41 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 16:10:39 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 15:40:38 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 15:10:37 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 14:40:35 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 14:10:35 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 13:40:33 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 13:10:32 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 12:40:32 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 12:10:29 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 11:40:28 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 11:10:27 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 10:40:26 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 10:10:26 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 09:40:24 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 09:10:23 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 08:40:22 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 08:10:20 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 07:40:20 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 07:10:18 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 06:40:17 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 06:10:16 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 05:40:14 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 05:10:14 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Jun 13 04:40:12 LogicMachine user.notice dhcp: setting dns servers: 8.8.8.8 8.8.4.4 Thanks, Roger RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - admin - 14.06.2017 Not needed, but there's no harm in it. These logs are stored in RAM and are not written to flash. RE: [PRE-RELEASE] LogicMachine firmware 2017.06 - rocfusion - 14.06.2017 (14.06.2017, 06:27)admin Wrote: Not needed, but there's no harm in it. These logs are stored in RAM and are not written to flash. ok thanks |
