Custom values - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Custom values (/showthread.php?tid=840) |
Custom values - Thomas - 15.06.2017 Hi I would like to show a mix of custom values and the original values. In short: If the replacement in custom values table exists use the custom value. In all other cases use the original object's value. Is it possible? What's going on: My problem are blinds. I want to show "Up" value for upper position (0%) and "Down" for lower position (100%) of blinds. And numbers for every other value. I understand I can put all values (1%,2%..99%) into the custom values table but this is not what I want to do. Do you have any suggestion? RE: Custom values - Erwin van der Zwart - 15.06.2017 Hi Thomas, Why not use the custom values? Here is a script to create objects with the wanted custom values in a second ...
Create objects with custom values.lua (Size: 6.1 KB / Downloads: 64)BR, Erwin RE: Custom values - Thomas - 15.06.2017 Thank you for the script. If I do it for more than 200 objects. Will it slow down speed of the application dramatically? RE: Custom values - Erwin van der Zwart - 15.06.2017 Hi Thomas, No i don't think so, its just a couple of bytes per item ( i guess 0.2 kB) , so on 200 it will be probably something like 40 kB extra in total. BR, Erwin |
