Passage from one HK/LM to another - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: OLD visualization (https://forum.logicmachine.net/forumdisplay.php?fid=9) +--- Thread: Passage from one HK/LM to another (/showthread.php?tid=852) |
Passage from one HK/LM to another - Gadjoken - 20.06.2017 Hi, I would like to know if there is a simple way to switch from viewing one HomeLynk / LM to another without nesting the visualization of the other but really opening up the visualization of the second HK / LM. Thanks. RE: Passage from one HK/LM to another - Erwin van der Zwart - 20.06.2017 Hi, Use this as custom javascript on object bit 1/1/1 in both controllers: Code: $(function() {
grp.listen('1/1/1', function(object, state) {
var value = object.value;
if (state == 'value') {
if (value == 0) {
$(location).attr('href', 'http://admin:admin@192.168.0.10/scada-vis');
} else {
$(location).attr('href', 'http://admin:admin@192.168.0.11/scada-vis');
}, true);
});BR, Erwin RE: Passage from one HK/LM to another - Gadjoken - 22.06.2017 Hi Erwin, Very good. Thanks |
