Enable RTU with settings - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Enable RTU with settings (/showthread.php?tid=856) |
Enable RTU with settings - FatMax - 21.06.2017 Is there a way to enable RTU with certain settings in a init script, and possible check if its already enabled and then ignore? RE: Enable RTU with settings - admin - 23.06.2017 Can you explain what are you trying to achieve? Are settings getting reset for some reason? RE: Enable RTU with settings - FatMax - 23.06.2017 When loading a backup onto a SL/HL, this setting doesn't come over with the backup. A init script in this backup could then check and rectify this. |
