Check connected tcp ports - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Check connected tcp ports (/showthread.php?tid=862) |
Check connected tcp ports - buuuudzik - 22.06.2017 Hello do somebody know: - how can I check currently connected tcp ports? - how can I reach the socket which is created and permanent used in resident script via event script? The solution is necessary for Sony Bravia TV. I must have permanent tcp connection to have ability to read status when TV is off. So for this solution I've prepared the resident script 0s: Code: require('socket')
if not sock_bravia then
-- bravia IP
ip = '192.168.2.102'
sock_bravia = socket.tcp()
sock_bravia:settimeout(3)
res, err = sock_bravia:connect(ip, 20060)
-- power-status
cmd = '*SEPOWR################\n' -- Check status power
if res then
res, err = sock_bravia:send(cmd)
if res then
res, err = sock_bravia:receive()
if res then
log('receive OK: ' .. tostring(res)) -- received ok
log('receive failed: ' .. tostring(err)) -- receive failed
log('send failed: ' .. tostring(err)) -- send failed
log('connect failed: ' .. tostring(err)) -- connect failed
os.sleep(5)But sometimes I want send command e.g. switch on but from event-based script. How can I reach currently port from other script? RE: Check connected tcp ports - admin - 22.06.2017 Each script is a separate OS process, this means you cannot access other process resources directly. You can create a local UDP server in your resident script which to proxy data from event scripts: https://forum.logicmachine.net/showthread.php?tid=399&pid=2015#pid2015 You can get a list of currently open TCP client connections like this: Code: clients = io.readproc('netstat -ptn | grep ESTABLISHED')RE: Check connected tcp ports - mlaudren - 23.06.2017 What about using storage to send command? in you resident script you read a table in storage and send all element you read, and in your event script you write all your command This way you have a FIFO and can send multiple command at a time: On, switch to channel X, volume Y, .... RE: Check connected tcp ports - buuuudzik - 23.06.2017 (23.06.2017, 12:27)mlaudren Wrote: What about using storage to send command? I've tested in the past this solution but storage is not so fast as must be. RE: Check connected tcp ports - mlaudren - 23.06.2017 (23.06.2017, 14:12)buuuudzik Wrote:(23.06.2017, 12:27)mlaudren Wrote: What about using storage to send command? What speed/ time response do you target? I have some script that use storage and I didn't notice delay during the execution. I'll do some test to see it that. RE: Check connected tcp ports - buuuudzik - 23.06.2017 I don't know exactly but this was my subject when I used the storage for such solution: https://forum.logicmachine.net/showthread.php?tid=399&highlight=somfy In that case I've tried push button to e.g. rotate the slat step by step and Somfy was very slow(~0,6s for sending one command). So when I clicked very fast 3 times then I had a problem also with storage and e.g. Somfy did only 2 steps. I've tested this on LM4 on old processor so I think it could also had some influence. When I've used UDP server for this the problem gone and CPU usage go to minimum level from very high. RE: Check connected tcp ports - Erwin van der Zwart - 23.06.2017 Storage is moved to redis DB so should be much faster then inside older FW. I would retry your previous tests as i think it's fast enough now. We used same kind of methode that mlaudren adviced in a TCP connection to Lutron and works pretty good. BR, Erwin RE: Check connected tcp ports - admin - 23.06.2017 You still have race condition if you do get - change - set, no matter what kind of storage engine is used. You can use Redis list operations (lpush/lpop) which are atomic, but then you will have to poll for list changes where you can use receive with timeout when using UDP. RE: Check connected tcp ports - rocfusion - 25.06.2017 Hi, I have been using this, https://forum.logicmachine.net/showthread.php?tid=842 This way storage is not required to send something from the event based objects. Works well. Thanks, Roger |
