How to write 3 byte RGB value - Printable Version
+--- Thread: How to write 3 byte RGB value (/showthread.php?tid=871)
How to write 3 byte RGB value - Mirco - 27.06.2017
I want to set the color of RGB Led by HL, how can I write, for example, the blue color?
In ETS I write this way: 0 0 255  (the datatype is 232.600 - RGB value 3x(0..255))
Thanks!
RE: How to write 3 byte RGB value - admin - 27.06.2017
You can use hex value, like 0x0000FF for blue only.
Or specify color in 0..255 range like this:
r = 0 g = 0 b = 255 rgb = bit.bor(bit.lshift(r, 16), bit.lshift(g, 8), b)
RE: How to write 3 byte RGB value - Mirco - 27.06.2017
Thank you! Smile
