dynamic widgets - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: dynamic widgets (/showthread.php?tid=887) |
dynamic widgets - Angeles - 04.07.2017 Hi: I need to do many widgets --- 48 -- and I ask if it would be possible to create one dynamic, that it could get the object where the widget is called and use it to do something..... Thanks... RE: dynamic widgets - admin - 04.07.2017 Can you give some more detail, what should the widget do? RE: dynamic widgets - Angeles - 05.07.2017 ok, I have one object that calls a widget. Is it possible to create a class that recovers that object not its value but its address? Thanks RE: dynamic widgets - admin - 05.07.2017 You can get the group address mapped to a visualization item like this: Code: var object = $('.myclass').data('object') |
