SD Card for LM - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: SD Card for LM (/showthread.php?tid=897) |
SD Card for LM - rocfusion - 11.07.2017 Hi, What class of microSD card can we use? Some of the cards have a higher transfer rate. Would there be an improvement in performance from the LM's? Is there any limitation for the microSD card, size? I have an old LM3 the card is going broke so I need to replace that. I will use Samsung I think. Thanks, Roger RE: SD Card for LM - admin - 11.07.2017 Higher class is preferable, though most commonly used files are cached in RAM, so the only difference you might get is faster start-up. Sizes up to 32GB are supported, but if using a recovery image then it will still use only 4GB. RE: SD Card for LM - rocfusion - 14.07.2017 Hi Admin, Will this work with the LM3? https://www.amazon.com/Samsung-MicroSD-Adapter-MB-MF32GA-AM/dp/B06XWZ7L1Q/ref=pd_sbs_147_1?_encoding=UTF8&pd_rd_i=B06XWZ7L1Q&pd_rd_r=5MHM93F31H0VTR2C46SZ&pd_rd_w=3IUHs&pd_rd_wg=scqWb&refRID=5MHM93F31H0VTR2C46SZ&th=1 Thanks, Roger RE: SD Card for LM - admin - 14.07.2017 Yes, any microSDHC (4-32GB) card should work. RE: SD Card for LM - rocfusion - 14.07.2017 Hi Admin, Thanks, does the speed of the SD affect writing to script storage? Thanks, Roger RE: SD Card for LM - admin - 14.07.2017 No, databases are stored in RAM and are synced to SD once in 30 minutes, so you won't gain much by using higher class cards. Class 10 is more than enough. RE: SD Card for LM - ricole87 - 26.11.2021 (14.07.2017, 07:12)admin Wrote: No, databases are stored in RAM and are synced to SD once in 30 minutes, so you won't gain much by using higher class cards. Class 10 is more than enough. Hi admin, what is filesystem type for LM? as i am changing new SD card for the LM. Document not mentioning what type of filesystem incase formating new SD card for LM. Br RE: SD Card for LM - admin - 26.11.2021 You don't need to format the card. Simply flash the whole recovery image as described here: https://openrb.com/reflash-logicmachine3-and-streaming-player-software/ RE: SD Card for LM - ricole87 - 26.11.2021 (26.11.2021, 07:26)admin Wrote: You don't need to format the card. Simply flash the whole recovery image as described here: https://openrb.com/reflash-logicmachine3-and-streaming-player-software/ thank Q ! Br RE: SD Card for LM - Loikeg - 05.03.2023 (11.07.2017, 06:35)admin Wrote: Higher class is preferable, though most commonly used files are cached in RAM, so the only difference you might get is faster start-up. Sizes up to 32GB are supported, but if using a recovery image then it will still use only 4GB. I had to replace the SD card of a Schneider Homelynk HW v1.3 because the card became read-only. Used Sandisk 32 GB card Recovery image created a 3rd partition of 3.25 GB. Is there a way to extend this partition to use the full capacity of the 32 GB SD card? RE: SD Card for LM - Daniel - 06.03.2023 SD card capacity does not matter as it is RAM which holds your horses. |
