Group addresses in Objects only appear by auto update - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Group addresses in Objects only appear by auto update (/showthread.php?tid=91) |
Group addresses in Objects only appear by auto update - Logic - 02.10.2015 Hi I am having a little problem with the Objects tab in the logic machine. This tab shows a list of group addresses but the list is only populated when auto update is enabled. I have tried importing an ESF file through Utilities but the Objects tab remains empty until auto update starts working. Also, whenever the browser is closed and then opened again later to access the Objects tab, every group address that was found earlier is gone and requires auto update to show them again. Is this how this is supposed to work? I was under the impression that when ESF files were imported that all the group addresses would be instantly visible in the Objects tab. Is there a way to see all the group addresses instantly within the logic machine that have been manually created or imported without the need to sniff for them first? RE: Group addresses in Objects only appear by auto update - admin - 05.10.2015 Which firmware version are you running? Importing ESF with auto update disabled populates the object tab properly on latest firmware. This setting only affects new objects and object values that are coming from visualization/scripts, KNX/TP or KNX/IP. RE: Group addresses in Objects only appear by auto update - Logic - 05.10.2015 Version: 20150917 Additional info:
RE: Group addresses in Objects only appear by auto update - admin - 05.10.2015 Can you try another browser like Firefox or Chrome? IE should work, but it is not officially supported. RE: Group addresses in Objects only appear by auto update - Logic - 05.10.2015 I got IE to work. The problem was bad encoding of the esf file. Country specific letters were all scrambled before but when importing the esf file with UTF-8 encoding instead of ANSI everything worked like it should in IE. RE: Group addresses in Objects only appear by auto update - nordom_lh - 30.10.2016 Thanks for this post, I had the same issue with 'é' 'è' char. I solved it by opening the .esf file with notepad++ and convert it from ANSI to UTF-8, reset all object in HomeLynk LM and import the converted .esf file solved the issue of blank page in object tab. (HL firmware 1.5.1, ETS 5). By the way on ETS 5 the esf export is in "extra" menu. RE: Group addresses in Objects only appear by auto update - admin - 31.10.2016 You can also use this tool for ESF conversion: http://openrb.com/convert/ |
