Schneider HomeLynk freeze after 2 minutes - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: General (https://forum.logicmachine.net/forumdisplay.php?fid=2) +--- Thread: Schneider HomeLynk freeze after 2 minutes (/showthread.php?tid=943) |
Schneider HomeLynk freeze after 2 minutes - Oskaro - 15.08.2017 Hello everyone ! I have a problem with HomeLynk. In my knx network i have 6 HomeLynk which work as like ip routers, But besides is Babtec homeserver. 1 HomeLynk after reboot works 2 minutes and suspend. Babtec sends packet only knx ip. Port 3671 is open and versions software is current. I dont have idea where is a problem in this device. Address which I send its 13/0/0. Filters are unlocked. When I try send packets from group monitor is likewise. Please help me !!! RE: Schneider HomeLynk freeze after 2 minutes - Erwin van der Zwart - 15.08.2017 Hi, What is freezing? The visu, the knx bus, the complete controller? Never seen this issue so need some more info... BR, Erwin RE: Schneider HomeLynk freeze after 2 minutes - Oskaro - 15.08.2017 (15.08.2017, 12:18)Erwin van der Zwart Wrote: Hi, Hi Erwin. When i send communication object from Babtec, HomeLynk work only 2 minutes. I see in Ets diagnostic communication objects only after 2 minutes after reboot HomeLynk), but access to website HomeLynk still work. When i made visu and added button on this HomeLynk works corretly. I will be recording video this problem tomorrow. RE: Schneider HomeLynk freeze after 2 minutes - Erwin van der Zwart - 15.08.2017 Hi, Yes please make a video as current described issue you are facing doesn't make any sense to me (: BR, Erwin RE: Schneider HomeLynk freeze after 2 minutes - AEK - 16.08.2017 (15.08.2017, 13:49)Oskaro Wrote:(15.08.2017, 12:18)Erwin van der Zwart Wrote: Hi, Hi, do you use any script on this HL? is there any errors in "error log" tab and "allerts" tab? RE: Schneider HomeLynk freeze after 2 minutes - mlaudren - 17.08.2017 If I understand, the homeLYnK is working correctly if you access the visu page, but does not respond to communication from babtec? look in the error tab, you may have something, or if you are using scripts, add try/catch / error log in your script |
