spacelYnk - modbus TCP slave - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: spacelYnk - modbus TCP slave (/showthread.php?tid=956) |
spacelYnk - modbus TCP slave - kaadeel - 23.08.2017 Hi! I have a problem. I use spacelYnk gateway and I want to use it as a slave from KNX to Modbus TCP in StruxureWare Building Operation. I used 'AN016_spaceLYnk_as_a_Modbus_slave' document for example. Despite the corect connect i have problem with read and send registers. Can I get help with scripting. Could anyone to explain step by step how to solve below tasks: 1 - I want to read value from KNX group (ex. 0/1/0) on Modbus Register Input. 2 - Sent value from Modbus Register Output to variable in spacelYnk group (ex. 0/1/5) Kind regards RE: spacelYnk - modbus TCP slave - admin - 23.08.2017 Can you use BACnet instead? It's much easier to setup. RE: spacelYnk - modbus TCP slave - Daniel - 23.08.2017 Hi Use bacnet IP instead of modbus and you don't have to use script. BR RE: spacelYnk - modbus TCP slave - kaadeel - 23.08.2017 (23.08.2017, 11:52)admin Wrote: Can you use BACnet instead? It's much easier to setup. In originally according to the guidelines in the project requires Modbus TCP, but after consultation is agree to using BACnet. so, how to do it by BACnet? BR RE: spacelYnk - modbus TCP slave - Daniel - 23.08.2017 Bacnet is already there Export objects which you want to see in SBO and then setup BACnet settings in system. As far I know in SBO you have to add bacnet network and discover devices. SE has another AN about this BR RE: spacelYnk - modbus TCP slave - Erwin van der Zwart - 23.08.2017 Hi, Check these links for homeLYnk or spaceLYnk integration into EcoStruxure Building Operation using BACnet http://www.schneider-electric.com/en/download/document/AN001_SL/ https://www.youtube.com/watch?v=Y7eHmnAMsLg BR, Erwin |
