Error in the console Error of register - Printable Version
+--- Thread: Error in the console Error of register (/showthread.php?tid=979)
Error in the console Error of register - Carlos Padilla - 06.09.2017
user-function-library 06.09.2017 11:09:30
Common functions:1: attempt to index global 'port' (a nil value)
stack traceback:
Common functions:1: in main chunk
does anyone know why I get this error when I execute the following command
a = { f1 = 10, f2 = 20 }
 for k,v in ipairs(a) do
 log(k,v)
-- all passed arguments will appear in Logs module
log(a)
RE: Error in the console Error of register - admin - 06.09.2017
Check your common function library
RE: Error in the console Error of register - Erwin van der Zwart - 06.09.2017
This is a non array structured table, so you should use this:
a = { f1 = 10, f2 = 20 } for key,value in pairs(a) do  log(key,value) end
Check this for explanation of the difference:
The difference between ipairs and pairs
