Set value of object with curl - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: Set value of object with curl (/showthread.php?tid=985) |
Set value of object with curl - baggins - 11.09.2017 Hi, I would like to set an object value from another machine. I can do this manually from a web browser using this url: Code: http://remoteusr:remotepasswd@192.168.0.40:80/scada-remote?m=json&r=grp&fn=write&alias=15/0/87&value=1When I use curl on the other machine as follows: Code: curl -0 -i -H "Accept: application/json" -H "Content-Type: application/json" -X POST http://remoteusr:remotepasswd@192.168.0.40:80/scada-remote?m=json&fn=write&alias=15/0/87&value=1the following is returned: Code: [1] 6322
[2] 6323
[3] 6324
[4] 6325
[2] Klaar r=grp
[3]- Klaar fn=write
[emm@bilbo 23]$ HTTP/1.1 200 OK
Server: nginx
Date: Mon, 11 Sep 2017 09:56:56 GMT
Content-Type: text/plain
Content-Length: 31
Connection: close
Invalid parameter "r" (request)The object value is not set. I'm not particularly familiar with curl and there are a million options to it, so can anyone help me out? Thanks. RE: Set value of object with curl - baggins - 11.09.2017 I've found the solution by using this command: Code: curl -0 -i -H "Accept: application/json" -H "Content-Type: application/json" --data "m=json&r=grp&fn=write&alias=15/&value=0" http://remoteusr:remotepasswd@192.168.0.40:80/scada-remoteRE: Set value of object with curl - admin - 11.09.2017 Or just escape the whole url with "" RE: Set value of object with curl - baggins - 11.09.2017 (11.09.2017, 13:32)admin Wrote: Or just escape the whole url with "" That also works indeed! Thanks. |
