Audio problem - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Amati.linea Streaming Player (https://forum.logicmachine.net/forumdisplay.php?fid=18) +--- Thread: Audio problem (/showthread.php?tid=999) |
Audio problem - m.elia - 18.09.2017 Hi, I have installed a Streaming player with integrated amplifier, now I’m facing a problem with the audio level. Once I adjust the output volume up to 50% (more or less), the output stops working (it seems to be related with the internal audio amplifier). I tried with different power supplies and different speakers, but the problem is always the same. I also tried to upgrade the firmware and reset the device to factory defaults, but nothing has changed. Could someone suggest something to do before “declaring” an hardware problem? Thank you. RE: Audio problem - edgars - 19.09.2017 Hi! please send me in private message your player serial number. |
