14.01.2016, 07:31
A5-20-01 is already in our to-do list
EnOcean profiles supported in LM
14.01.2016, 07:31
![]() [attachment=113 Wrote:jorgenbl pid='704' dateline='1450642519'] (09.11.2015, 11:03)Hello Edgars, Wrote: Are you planning to add following profiles :
03.02.2016, 01:03
+1 for EEP A5-20-01,
thanks
04.02.2016, 09:08
Hi Zubin,
regarding 1) I experienced the same as you. The 00-00-00 Raw 4-byte Profile mapped to you actuator under the "KNX >> Enocean" tab and "Device Mapping" has an option "Send timer". It will send as often as you specify here, the last value set for the object. Unfortunately I found that this send timer value can maximum be set to 1000 seconds. At that interval it will set the value back to whatever configured on the object in the Logicmachine (Assuming you have changed this with some other system/Switch). I have not been able to turn off this interval either. The solution I found to this problem (not very elegant, but works, is to set a dummy value in the script, right after the desired value) The dummy value then set to the object will not be readable by the actuator, thus not change it's current last working value. This results in when the interval occurs the dummy value is sent instead. I guess this will not be a problem when they update the firmware and correct profiles are available. Here´s my script: Code: -- dimming regarding 2) I still use the teach in procedure as outlined before. It works for me. You might be correct though ![]()
04.02.2016, 09:13
We will add an option to set timer value to 0 so you can disable it completely in next FW.
Hello Jorbengl,
Thanks for your reply. Meanwhile i will continue with your dummy script, until the new firmware is released. Also have you done scripting for ELTAKO Curtain Controller - FSB61NP-230V, i am planning to do, so if you can share me the scripting it would be great. Also what else Eltako product you have tested with LM ? (Just for information sharing) Thanks, Reply, ZUBIN |
