12.03.2019, 09:38
I'm having difficulties with connecting to a Logic Machine 5 through ETS. I have forwarded port 3671 to 36003 (UDP), but for some reason it doesn't work. I wasn't able to telnet it either. I tried telnetting it inside the internal network (telnet LMIP 3671) but that didn't work either. That means though there should be some different problem. I'm pretty sure the forward is correct, since the forward for Logic machine web itself works flawlessly on port 36002. Is there a setting inside of LM I should check? I compared all the settings of two LMs and they're the same.
