Mass edit Visualization Parameters
I am facing issues when trying to mass edit step in Circular Slider.
I attach a short video.
Is it a bug or is something I am doing wrong?
Thanks in advance!
.zip   MASS EDIT VISU PARAMETERS.zip (Size: 6.1 MB / Downloads: 13)
Clear browser cache
(18.02.2022, 13:55)Daniel Wrote: Clear browser cache
It worked partially for some objects but actually no. See attached video.
In visualization tab when I access objects visualization parameters settings are as should. However, they are not applied in touch visu. Any ideas?
How do I know when I have to clear cache?
.zip   MASS EDIT VISU PARAMETERS-1.zip (Size: 8.34 MB / Downloads: 16)
You might have local visualization parameters set which have higher priority. In the editor click "Visualization parameters" under the "Main object" and see if local parameters are set. If it still does not help then send you backup via PM.
