LM5 pretty slow
since few weeks my LM5 is very very slow
load and memory is OK but UI and event script are so slow
i try to reboot it, no improvement
info:
CPU model : ARMv7 Processor rev 5 (v7l)
Linux kernel version: 4.4.302
System uptime: 0d 0h 10m
Load averages: 0.00 0.00 0.00
Total system memory: 122.1M
Used: 15.5M (13%)
Free: 106.6M (87%)
Buffered: 0.9M
Cached: 9.6M
Firmware: 20230607
how to debug deeper ?
any idea are welcome ?
Did you change anything in the installation?
(15.01.2024, 08:49)Daniel Wrote: Did you change anything in the installation?
no
quick exemple even icmp is causing issue
ping logic PING logic.geo6.net (192.168.13.50): 56 data bytes 64 bytes from 192.168.13.50: icmp_seq=0 ttl=64 time=0.474 ms Request timeout for icmp_seq 1 64 bytes from 192.168.13.50: icmp_seq=2 ttl=64 time=0.454 ms Request timeout for icmp_seq 3 64 bytes from 192.168.13.50: icmp_seq=4 ttl=64 time=0.478 ms Request timeout for icmp_seq 5 Request timeout for icmp_seq 6 64 bytes from 192.168.13.50: icmp_seq=7 ttl=64 time=0.654 ms Request timeout for icmp_seq 8 Request timeout for icmp_seq 9 64 bytes from 192.168.13.50: icmp_seq=10 ttl=64 time=0.448 ms Request timeout for icmp_seq 11 64 bytes from 192.168.13.50: icmp_seq=12 ttl=64 time=0.503 ms 64 bytes from 192.168.13.50: icmp_seq=13 ttl=64 time=0.579 ms 64 bytes from 192.168.13.50: icmp_seq=14 ttl=64 time=0.655 ms 64 bytes from 192.168.13.50: icmp_seq=15 ttl=64 time=0.484 ms Request timeout for icmp_seq 16 Request timeout for icmp_seq 17 Request timeout for icmp_seq 18 Request timeout for icmp_seq 19 Request timeout for icmp_seq 20 Request timeout for icmp_seq 21
i just test to boot on a recovery card
i'm even not able to diplsay the sysflash
ping is also erratic
ping 192.168.0.10         1m 11s PING 192.168.0.10 (192.168.0.10): 56 data bytes 64 bytes from 192.168.0.10: icmp_seq=0 ttl=64 time=0.384 ms Request timeout for icmp_seq 1 Request timeout for icmp_seq 2 Request timeout for icmp_seq 3 Request timeout for icmp_seq 4 Request timeout for icmp_seq 5 Request timeout for icmp_seq 6 Request timeout for icmp_seq 7 Request timeout for icmp_seq 8 64 bytes from 192.168.0.10: icmp_seq=9 ttl=64 time=0.428 ms 64 bytes from 192.168.0.10: icmp_seq=10 ttl=64 time=0.417 ms 64 bytes from 192.168.0.10: icmp_seq=11 ttl=64 time=0.636 ms Request timeout for icmp_seq 12 64 bytes from 192.168.0.10: icmp_seq=13 ttl=64 time=0.474 ms Request timeout for icmp_seq 14
any idea ??
I would start with isolating the product by making a direct connection between the controller and your PC without any network components in-between to rule out any network issues and or IP conflicts..
