Airthings API
Hey everyone,
I'm want to read temperature and humidity data from the Airthings API through LM5, but I'm new to working with APIs . Could someone please help me get started?
https://developer.airthings.com/api-docs
https://developer.airthings.com/docs/api...umentation
Thanks in advance!
Similar integration: https://forum.logicmachine.net/showthrea...4#pid31274
(26.06.2024, 11:05)admin Wrote: Similar integration: https://forum.logicmachine.net/showthrea...4#pid31274
In case someone needs it, below is a scheduled script that runs every 5 minutes to retrieve temp data from some sensors and write them into LM5 groups. (I'm pretty sure that it could be improved)
local https = require('ssl.https') local json = require('json') local ltn12 = require('ltn12') -- Airthings API endpoints and credentials local tokenEndpoint = 'https://accounts-api.airthings.com/v1/token' local clientId = 'xx' local clientSecret = 'xx' -- local deviceSerialNumber = '3130000665'  -- Specific device serial number local devices = {     { serialNumber = 'xx', location = '7east' },     { serialNumber = 'xx', location = '7west' },     { serialNumber = 'xx', location = '7mid' } } local accessToken -- Custom logging function -- Function to get access token function getAccessToken()     local requestBody = 'grant_type=client_credentials'         .. '&client_id=' .. clientId         .. '&client_secret=' .. clientSecret         .. '&scope=read:device'     local response_body = {}     local _, code, headers, status = https.request{         url = tokenEndpoint,         method = 'POST',         headers = {             ['Content-Type'] = 'application/x-www-form-urlencoded',             ['Content-Length'] = #requestBody         },         source = ltn12.source.string(requestBody),         sink = ltn12.sink.table(response_body)     }     local response = table.concat(response_body) --    log("DEBUG", "Response body: " .. response) --    log("DEBUG", "HTTP status code: " .. tostring(code)) --    log("DEBUG", "HTTP status: " .. tostring(status))         if code == 200 then         local jsonResponse = json.decode(response)         accessToken = jsonResponse.access_token         log("INFO", 'Access token received: ' .. accessToken)     else         log("ERROR", 'Error fetching access token: ' .. tostring(code) .. ' ' .. tostring(status))     end end -- Function to get data from a specific device function getDeviceData(serialNumber)     local deviceDataEndpoint = 'https://ext-api.airthings.com/v1/devices/' .. serialNumber .. '/latest-samples'     local response_body = {}     local _, code, headers, status = https.request{         url = deviceDataEndpoint,         method = 'GET',         headers = {             ['Authorization'] = 'Bearer ' .. accessToken         },         sink = ltn12.sink.table(response_body)     }     local response = table.concat(response_body) --   log("DEBUG", "Device data response body: " .. response) --   log("DEBUG", "HTTP status code: " .. tostring(code))   --  log("DEBUG", "HTTP status: " .. tostring(status))         if code == 200 then         local jsonResponse = json.decode(response)         return jsonResponse     else --       log("ERROR", 'Error fetching device data: ' .. tostring(code) .. ' ' .. tostring(status))         return nil     end end -- Main script getAccessToken() -- if accessToken then --    local data = getDeviceData(deviceSerialNumber) --    if data then --        log("INFO", "Data for device " .. deviceSerialNumber .. ": " .. json.encode(data)) --    end -- end -- Main script getAccessToken() if accessToken then     i = 1   -- Initialize index     for _, device in ipairs(devices) do             i = i + 1    -- Increment index for group address         local data = getDeviceData(device.serialNumber)         if data then             local temperature = tostring(data.data.temp)             log("INFO", "Temperature " .. device.location .. " == " .. temperature)         -- Inside your loop for devices        grp.checkwrite("32/1/" .. i, temperature)  -- Write temperature to group address              -- log(i)         end     end end
