Login ellular failed worn username o password
Greetings
I have a problem with accessing the LM from a mobile phone, from a PC everything is OK, from the phone it tells me that the user or password is wrong, I use the administrator access both from the PC and from the mobile phone.
What happened ?
Try clearing browser cache and make sure the credentials are correct.
Which fw do you use?
