Hi we are using bacnet package not bacnet app for bacnet client function.
We need to change bacnet port from 47808 to 47810. There is a bacnet device in 47810 we found via another bacnetscan app. Can you check the script below for scan device. Also can you share bacnet read command for different port please ?
Hi Daniel,
There are 2 bacnet points. one is bacnet value other is binary input. We read binary value but we can't read binary input. Here is the detailed pictures of the points which are taken from yabe.
