28.10.2025, 18:02
I am creating a profile with Modbus Profiler application
I am trying to send a single Modbus TCP frame using function 16 (0x10) to write 4 consecutive registers (0x0003–0x0006) but only register 0x0003 is sent with the function (0x10). I have tried sending from Modbus Poll and it works perfectly and I have also read with Modbus Slave what LM sends and I have received
Rx:269-17:49:44.026-00 01 00 00 00 09 01 10 00 03 00 01 02 00 05
Can you tell me where the error is?
Thank you very much!!
{"manufacturer":"DT","description":"DT16",
"mapping":[
{"bus_address":"36/3/0","bus_datatype":"uint16","write_only":true,"address":2,"bus_write":false,"datatype":"uint16","writable":true,"type":"register","name":"Write Relay"},
{"bus_address":"36/3/1","bus_write":true,"datatype":"uint16","bus_datatype":"uint16","address":3,"type":"register","writable":true,"write_multiple":true,"name":"Advance Write Type "},
{"bus_address":"36/3/2","bus_write":true,"datatype":"uint16","bus_datatype":"uint16","address":4,"type":"register","writable":true,"write_multiple":true,"name":"Advance password"},
{"bus_address":"36/3/3","bus_write":true,"datatype":"uint16","bus_datatype":"uint16","address":5,"type":"register","bus_write":true,"writable":true,"write_multiple":true,"name":"Advance Write Relay"},
{"bus_address":"36/3/4","bus_write":true,"datatype":"uint16","bus_datatype":"uint16","type":"register","address":6,"writable":true,"bus_write":true,"name":"Advance Write Time "},
{"bus_address":"36/0/1","value_delta":0.2,"datatype":"int16","bus_datatype":"bool","address":22,"type":"register","writable":false,"bus_write":false,"name":"Estado entrada 1"},
{"bus_address":"36/0/2","value_delta":0.2,"datatype":"int16","bus_datatype":"bool","address":23,"type":"register","writable":false,"bus_write":false,"name":"Estado entrada 2"},
{"datatype":"int16","bus_datatype":"bool","address":24,"writable":false,"type":"register","name":"Estado entrada 3"},{"datatype":"int16","bus_datatype":"bool","address":25,"writable":false,"type":"register","name":"Estado entrada 4"},
{"datatype":"int16","bus_datatype":"bool","address":26,"writable":false,"type":"register","name":"Estado entrada 5"},{"bus_address":"36/1/1","value_delta":0.2,"datatype":"int16","bus_datatype":"bool","address":54,"type":"register","writable":false,"bus_write":false,"name":"Estado salida 1"},
{"bus_address":"36/1/2","value_delta":0.2,"datatype":"int16","bus_datatype":"bool","address":55,"type":"register","writable":false,"bus_write":false,"name":"Estado salida 2"},{"datatype":"int16","bus_datatype":"bool","address":56,"writable":false,"type":"register","name":"Estado salida 3"},
{"datatype":"int16","bus_datatype":"bool","address":57,"writable":false,"type":"register","name":"Estado salida 4"},{"datatype":"int16","bus_datatype":"bool","address":58,"writable":false,"type":"register","name":"Estado salida 5"}
}Can you tell me where the error is?
