LogicMachine Reactor Dimmer
LogicMachine5 Reactor Dimmer is all-in-one cross-standard controller uniting in one device gateway functionality, cloud service integration, complex network logic engine, easy-to create visualization platform, IP Router, I/Os and much more.
Hightlights:
  • 12 I/O ports (Analog input/output, Voltage output, Current output)
  • LM5 Reactor Dimmer has built-in KNX TP1, 2 x DALI masters, 1-Wire, EnOcean bi-directional interface (optional), two serial interfaces
  • Power-over-Ethernet powering
  • Application development and application store
  • Cloud ready device with Microsoft Azure, Amazon Web Services and other services supported
  • Gateway and uniform way of control of KNX, ModBus RTU/TCP, BACnet IP, DALI, 1-Wire, EnOcean (optional), DMX, M-Bus, GSM and more
  • Unlimited scenario and logic engine
  • Unlimited visualization platform for PC and for touch devices
  • Size: 6 DIN units
  • Remote KNX bus control and KNX device reprogramming
  • Object logging with trends support and data exporting to external servers
  • Optional 3x more powerful CPU than all previous LogicMachine versions
[Image: EMBS_LM5_RD-300x230.png]
See here i.MX28 (CPU of LM2, LM3, LM4) and i.MX6 (optional 3x speed CPU for LM5 series devices) comparison tests: http://openrb.com/imx28-vs-imx6-cpu-test...icmachine/
Here is more information on LM5 Reactor Dimmer: http://openrb.com/logicmachine5-reactor-dimmer/
LM comparison table: http://openrb.com/wp-content/uploads/201...3.2017.pdf
