08.11.2024, 11:42
Hello
I have a problem with high TP repeats. It seems that LM5 does not send acknowledge although I have enabled that function.
You can see all the repeat telegrams on the screenshot below. For testing purposes, KNX line LM5 is connected to has no other devices than KNX power supply and USB interface.
Firmware version is 20240426. There are 4 different LM5 on this installation, and all 4 has the same issue.
I have tried multiple settings with no luck.
