Good morning Edgars and team;
I have integrated a SAM3000 network analyzer accessing all the measurement values with the record types 0x03 and 0x04 but to perform the date update of the equipment, i need to access using register type 0x0E. In the Logic modbus library I have access to the type registers: "coil (0x01) discreteinput (0x02) register (0x03) inputregister (0x04)".
The protocol that I have to implement is the following:
Is it possible using script to send data byte by byte in a string or can you guide me how to do it if possible ?.
Thank you very much for your help and comments.
