Email settings
Been trying to get the settings correct using my office365 account.
But i tried changing this script for the FB_mail. This has i guess different settings.
And the secure is different i believe. I think it is TLS1.2 but dont know.
And i am not getting any error in log.
Has anybody had trouble with other email clients.
12345678910111213141516171819202122232425262728293031323334353637383940414243444546474849505152535455
--- [Function] fbe_mail --- Send email --- [Comment] --- This module will sent email if trigger receive value different than 0.   --- [Input] --- Trigger [object] --- To [value, object, storage] --- Subject [value, object, storage] --- Message [value, object, storage] function fbe_mail(input, to, subject, message)  if (input and input ~= 0) then           -- make sure these settings are correct  local settings = {    -- "from" field, only e-mail must be specified here    from = 'example@gmail.com',    -- smtp username    user = 'example@gmail.com',    -- smtp password    password = 'mypassword',    -- smtp server    server = 'smtp.gmail.com',    -- smtp server port    port = 465,    -- enable ssl, required for gmail smtp    secure = 'sslv23',  }  local smtp = require('socket.smtp')  if type(to) ~= 'table' then    to = { to }  end  for index, email in ipairs(to) do    to[ index ] = '<' .. tostring(email) .. '>'  end  -- message headers and body  settings.source = smtp.message({    headers = {      to = table.concat(to, ', '),      subject = subject,      ['Content-type'] = 'text/html; charset=utf-8',    },    body = message  })  -- fixup from field  settings.from = '<' .. tostring(settings.from) .. '>'  settings.rcpt = to  log(smtp.send(settings))      end end
Tested another script:
-- send an e-mail
  local settings = {
    -- smtp username
    -- smtp password
    -- smtp server
    -- smtp server port
    port = 465,
    -- enable tls, required for gmail smtp
    secure = 'tlsv1_2',
    to = { to }
  -- fixup from field
  local from = '<' .. tostring(settings.from) .. '>'
    headers = {
      subject = subject,
      ['From'] = from,
    body = message
  settings.from = from
  settings.rcpt = to
  return smtp.send(settings)
Now getting this error:
FB Event for 32/1/20 07.05.2019 21:10:01
Library socket/tp:0: attempt to index a nil value
stack traceback:
[C]: in function 'send'
User library FB_Email:52: in function 'fbe_mail'
User script:8: in main chunk
FB Event for 32/1/20 07.05.2019 21:40:31
User script:8: attempt to call global 'fbe_mail' (a nil value)
stack traceback:
Can you send login, password and SMTP server address via PM so we can test locally?
(08.05.2019, 04:40)admin Wrote: Can you send login, password and SMTP server address via PM so we can test locally?
Pm sent.
Use these settings (change from/user/password as needed):
local settings = {     from = '***',     user = '***',     password = '***',     server = 'smtp.office365.com',     port = 587,     secure = 'tlsv1_2',     starttls = true, }
If this does not work then you might need to update LuaSocket library. Which firmware version are you running?
(08.05.2019, 08:51)admin Wrote: Use these settings (change from/user/password as needed):
HW: LM5 Lite + Ext (i.MX6)
SW: 20180822
Will test it now.
This worked great. Thanks for help..
