14.11.2020, 18:32
I have just started to look at the visualization so this is all new to me. So forgive me for any stupid questions...
I've tried a couple of the widgets like the CO/humid/temp widget and weather station widget. However, I've noticed that not all objects are available for selection. E.g. for humidity I had to change my object type to 09.001 temperature. 09.002 did not work. Besides when I found out this and could select the correct object the displayed percentage does not match the object parameter so there appears to be some scaling. 45% on group object is displayed as 18% in the widget.
The latter seems strange. Is there some sort of scaling/conversion in the widget? If so, how can you identify this property?
I would also like to identify what kind of object datatypes are allowed in the widget parameters. It takes some time just experimenting with the object type settings...
