Vertical Scroll on DIV
I'm trying to insert a scrollable DIV on a plan. Inside it, there is a table which can vertically overflow (depending on the number of lines in the table).
In older firmwares I'm using this code and it's working:
var quadre = $("<div id='requadre'></div>").css({       position: 'relative',       width: 1800, height: 800,       top: 70,  left: 100,       border: '1px solid white',       overflow: 'auto',       background: 'black',   }).appendTo('#plan-59');
In newer firmwares, the scroll bar appers but it seems disabled...
Any idea about what can be happening?
Add pointer-events: all to the CSS properties:
var quadre = $("<div id='requadre'></div>").css({       position: 'relative',       width: 1800, height: 800,       top: 70,  left: 100,       border: '1px solid white',       overflow: 'auto',       background: 'black',       'pointer-events': 'all'   }).appendTo('#plan-59');
(14.09.2021, 07:27)admin Wrote: Add pointer-events: all to the CSS properties:
Ok, now it works!
It's something that has been changed in new firmware?
It has been like this from the start, not sure why it worked in older firmware.
(14.09.2021, 07:54)admin Wrote: It has been like this from the start, not sure why it worked in older firmware.
Ok, thanks!
