mosquitto bug
Hello, on one particular LM these 2 errors keep on happening:
the first one in a script that loads mosquitto ( require('mosquitto') )
error loading module 'mosquitto' from file 'Library mosquitto.so': Error relocating /usr/lib/libmosquitto.so.1: ENGINE_ctrl_cmd: symbol not found stack traceback: [C]: at 0x000550cc [C]: in function 'require'
the second one directly from LMCloud app:
error loading module 'mosquitto' from file '/usr/lib/lua/mosquitto.so': Error relocating /usr/lib/libmosquitto.so.1: ENGINE_ctrl_cmd: symbol not found
Do you have any idea how to solve this?
Which firmware version do you have? Have you updated mosquitto package manually?
(26.08.2022, 10:54)admin Wrote: Which firmware version do you have? Have you updated mosquitto package manually?
Firmware version is 20210521. Yes I did update mosquitto (trying to solve this issue), but even after doing so, the problem keeps on happening. The package versions are libmosquitto 2.0.14-1
and luamosquitto 20210301 and mosquitto 2.0.14-1
Install 2021.12 firmware and do not update the package manually: https://forum.logicmachine.net/showthread.php?tid=3755
