Modbus Read_swap function
I've run some tests with the new modbus profiler app, basically if I upload a JSON with Read_swap not globally set but individually in every register LM5 seems to ignore it, but if I set it from the modbus profiler and then download it it's ok, for example:
this JSON:
    "manufacturer": "IO",
    "description": "TEST",
    "read_swap": "bw",
    "mapping": [
            "type": "register",
            "name": "TEST",
            "address": 0,
            "datatype": "int16",
            "bus_datatype": "int16",
            "writable": true,
            "read_swap": "n"
Uploaded, saved and downloaded results in this:
    "read_swap": "bw",
    "mapping": [
            "type": "register",
            "name": "TEST",
            "address": 0,
            "writable": true
but if i set read swap to none in the app, save and download the output is correct.
Am I doing something wrong?
Thanks for letting us know. Updated Modbus profiler app is available in our app store.
You're welcome, thank you for your fast reply and fix.
