Threads: 86
10 hours ago
(This post was last modified: 10 hours ago by gdimaria.)
I need to create thirty pages, one for each floor of a skyscraper.
I'd like to use a vertical slider (1-30) in the homepage, next to the image and then, based on the floor selected, jump to the relative page (/apps/data/visu/#xxx).
How could I do it?
Peppe
Threads: 30
You can do it like this, just create more ifs and put corect plan IDs
localbus.listen('object', '0/0/1', (value) => {
if (value==0) {
Visu.showPlan(7);
else if (value==1) {
Visu.showPlan(17);
else {
Visu.showPlan(13);
Threads: 8
5 hours ago
(This post was last modified: 5 hours ago by Erwin van der Zwart.)
That can be done with an extra virtual object, press ok binary object with event based script and write the slider value to the virtual object that is attached to the grp.listen function.
