31.05.2017, 12:46
I am running 1.2.1 of spacelynk now. Is the new firmware 100% complete or should I wait.
I found a bug in Modbus profiles in 1.2.1 firmware. When adding new profile the names from profile and knx adress is automatically transfered. But if the modbus is updated and gets values then the knx adresses is automaticaly added with blank names. This should be added once the Modbus profile is made.
Now i have to change the adress of modbus device so it doesnt get updated. Then delete all the objects with blank names.Then open the modbus mapping of the device and manually add one by one group adress to get the names correct.
At last I can change the modbus adress back to the correct one so the group adress gets the values... A little confusing
