Power failure - DALI is not working correctly
Hi!
Yesterday we lost the power to our house. when it came back my DALI lightning (controlled through RS485 and LM) was not working properly.
in LM, scene value shows 0, but some of the lamps in that scene is still on. Tried to set each individual DALI lamp to 0, but this only works every 2-5 times.
if i run a scene, some of the lamps will go off, but it appears to"lag" some seconds. if i repeatidlu press the off button, eventually it will go of (5-30times)
tried to restart LM, tried to take the power again, but no change.
LM Reactor V3 with 2- DALI gateways (They both show up in LM with all lamps)
any ideas??
Do you have any other dali interface to check if the ballast didn't lost its settings somehow? Check DALI PSU if it is working correctly.
Of course it was the power supply for the DALI gateways. thanks for quick reply! Smile Smile Smile
