07.11.2018, 06:49
Hi, I have added two Fibaro Dimmer 2, and are using the Aeotec Z-stick. The problem I am having is when dimming with a dimmer widget in Mosaic.
Steps to reproduce are:
Are anyone else experiencing this? Do I have to create a "mapping" object that maps 0-99 to 0-254 to use the default widgets?
Running the 20180604 Z-Wave application, and 20180828 LogicMachine
- Add Fibaro Dimmer 2 to network.
- Set first level object to new object, unchecked write to bus, unchecked polling and save.
- Add normal dimmer widget in Mosaic, set both dimmer and status object to the newly created object.
- Test
