importing esf file
it is possible to write a file.esf setting the right parameters? If yes, is there a guide with all parameters?
For example I need:
- data type (bool,int, float ecc).
- units
I know only this:
Virtual.Virtual.32/1/1    name_1    Uncertain (1 Byte)    Low
thanks
PS: I need this because I have to add a lot of virtual group address (like 1000 addresses)
You can use a script that calls grp.create and creates objects with required parameters. ESF does not allow to specify data type only data length. Units are also not supported there.
Thanks, is there a full manual with all parameters/types?
Common parameters are specified here: https://openrb.com/docs/lua.htm#grp.create
Thanks again!
