20.05.2022, 13:50
(This post was last modified: 20.05.2022, 14:02 by cdebackere.)
Is try to active/show and desactivare/hide a command button icon on the basis of the status object value.
Ideally, the element is always visible (adding an On, active icon and an Off, passive/greyed icon), but only can be selected/activated/clicked when value of status object is true
I added JS, but doesn't seem to do the trick
$(function() {
$('.hidden-by-value').each(function(_, el) {
var addr = $(el).data('object');
if (addr) {
grp.listen(addr, function(obj) {
var value = obj.value;
$(el).css('visibility', if value {'visible'} else {'hidden'});
Do I overlook something?
is 'object' correct? Or is this the main abject, and not the status object?
Thx
$(function() {
if (addr) {
Thx
Don't ask what we can do in KNX but wonder what we can't - www.KNXlogic.eu
