Object Logs
Hello all,
I would like to implement the following: Monitoring of window contacts and presence detectors in a building. First thought was to use the object logs. Since here time and date ... are clearly displayed. However after a test, only 1000 entries can be stored. Is it possible to allocate more memory here or increase the entries. I would like to save up to 48 hours and then it can be overwritten again. Or is it possible to switch the monitoring on/off via a group address (to save memory, for example From 6:00pm the contacts should be monitored until 7:00am. after that the monitoring is no longer necessary. Because if I let it run during the day the memory is too fast full/ will be overwritten).
Anyone got an idea?
(Screenshot is just a Test, not the real controller)
-F.Braun
Log size can be changed in Utilities > General configuration. It is limited to a number of entries not a date/time period.
Also see this thread: https://forum.logicmachine.net/showthread.php?tid=4187
