02.04.2024, 21:40
I have a widget that loads multiple iFrames showing weather info and one of them has the format https://<base_url>/#dYYYY-MM-DD
I can use the dynamic url examples from the forum to use a virtual group to trigger the changing url, but calculation of the string is simple in javascript and I would prefer to have things done in one place.
How do do I apply the src change every time this widget/iFrame is loaded without using a virtual group?
This works:
Attempt that does not work:
This works:
$(function(){
grp.listen('0/250/247', function(object) {
let d = new Date();
let forecastDate = d.getFullYear() + '-' + ('0' + (d.getMonth() + 1)).slice(-2) + '-' + ('0' + d.getDate()).slice(-2);
$('.hourlyforecastbak').find('iframe').attr('src','https://reg.bom.gov.au/places/vic/melbourne/forecast/detailed/#d' + forecastDate);
}, true);
});Attempt that does not work:
$(function(){
$('iframe').load(function() {
let d = new Date();
$('.hourlyforecast').find('iframe').attr('src','https://reg.bom.gov.au/places/vic/melbourne/forecast/detailed/#d' + forecastDate);
}, true);
