18.01.2026, 21:48
Good evening,
I've loaded a Logic Machine 5 with a large number of objects, some virtual, some standard, etc.
My question stems from another issue: the vast majority of these objects share two letters that are almost always repeated, specifically the following naming convention: "P1". (Image attached.)
My question is quite simple: I want to create a backup and load these objects into two other Logic Machines. The problem is that in the second and third Logic Machines, instead of "P1", I need to replace it with "P2" and "P3".
Is it possible to do this without having to go object by object? Is there a quick way to do it? Thank you very much.
Best regards,
Alejandro A.
Best regards,
Alejandro A.
