VISU slide value %
is it possible see the status value in the button of the slide ?
(inside the blu button)
Alberto
KNX Advanced Partner + Tutor
Add to Custom CSS:
.slider-handle:after {   background-color: transparent;   display: block;   top: 50%;   left: 0 !important;   right: 0 !important;   transform: translate(0, -50%) !important;   font-size: calc(var(--slider-base-size) / 3); }
is it possible repeat the +/- step by hold the button ?
Alberto
Using 4-bit dimmer is a better solution for this.
(15.01.2026, 13:21)admin Wrote: Add to Custom CSS:
can you help me with the value on vertical slide ? See the image below, please
Change top: 50%; to top: 50% !important;
