13.03.2026, 09:57
If I open a port through the router, could I connect to a logic machine via the WAN IP address?
Puerto Externo = WAN port
Puerto Interno = LAN port
Remote connection via http server
13.03.2026, 09:57
Puerto Externo = WAN port Puerto Interno = LAN port
13.03.2026, 10:45
What I want is to access the SCADA system, that is, the logic machine, through its static IP address. The problem I've encountered is that the network card I installed in the router doesn't have a static IP address, so the HTTP or HTTPS option won't work.
I'm looking at the VPN option as a zero-tier solution.
13.03.2026, 11:54
Have you configured a valid gateway and DNS in Network > Interfaces > eth0?
13.03.2026, 12:03
Your gateway IP is in another subnet, this setup won't work.
Either the gateway is wrong and should be 192.168.0.1 or LM IP must be in the 192.168.1.x range.
13.03.2026, 13:20
You are right, my device's gateway was my router's ip, now i see my LM in zerotier
I apologize for bringing up the same issue again.
As I've explained several times, I have a building with three logic machines connected to a router. I need to establish a remote connection through that router so that someone can access the logic machines. We've assigned static IPs to each logic machine: 192.168.0.11 192.168.0.12 192.168.0.13 Is there any way to remotely access the logic machines and their BACnet IPs? |
