email via application
Hello, one of the features of the application we are developing is to periodically send an email with a CSV report attached. We implemented this using a script, and it works very successfully.
However, when we tried to embed this functionality into the application's index.lp file, we were unable to send even a plain email, let alone one with an attachment. This is the same Logic Machine where the email works perfectly fine via scripts.
I am sharing the working script below. How can we properly integrate this into the application?
--Gmail (smtp) username
user = '***@gmail.com'
--Gmail (smtp) password
password = '***'
--From
from = '<' .. user .. '>'
alias_from = 'gonderenhesap@gmail.com'
--REceiver
to = '***@***.com'
alias_to = '***@***.com'
--Email subject
subjectpart1 = 'Alarmlar'
subjectpart2 = 'Logic Machine Tarafindan Gonderildi'
--Message
epilogue = 'Mesajin sonu'
-- Get all alerts from DB
alerts_table = db:getall('SELECT * FROM alerts')
-- csv buffer
buffer = {}
-- format csv row
csv = string.format('%q,%q,%q', "ID", "ALERT", "ADDED TO LIST")
-- add to buffer
table.insert(buffer, csv)
-- add empty line to buffer
table.insert(buffer, "")
-- Loop through alerts_table
for _, alerts in ipairs(alerts_table) do
  -- format csv row
  csv = string.format('%q,%q,%q', alerts.id, alerts.alert, os.date("%x %X", alerts.alerttime))
  -- add to buffer
--Create table to include mail settings
local settings = {
    from = from,
    rcpt = to,
    user = user,
    password = password,
    server = 'smtp.gmail.com',
    port = 465,
    secure = 'sslv23',
--Create attachment inside FTP server
src = 'AlertExport_'.. os.date('%Y-%m-%d %H#%M#%S') .. '.csv'
dst = '/home/ftp/' .. src
log(io.writefile(dst, buffer))
log("file created")
log(dst)
--Create subject
subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2
--Load required modules to send email with attachment
local smtp = require("socket.smtp")
local mime = require("mime")
local ltn12 = require("ltn12")
--Create e-mail header
settings.source = smtp.message{
headers = {
          from = '' .. alias_from .. ' ' .. from .. '',
          to = '' .. alias_to .. ' ' .. to .. '',
          subject = subject
--Load attachment inside body
body = {
preamble = "",
[1] = {
        headers = {
          ["content-type"] = 'text/plain',
          ["content-disposition"] = 'attachment; filename="'..src..'"',
          ["content-description"] = '.. src ..',
          ["content-transfer-encoding"] = "BASE64",
        body = ltn12.source.chain(
          ltn12.source.file(io.open(dst, "rb")),
          ltn12.filter.chain(
          mime.encode("base64"),
          mime.wrap()
      epilogue = epilogue
--Send the email
r, e = smtp.send(settings)
--Create alert when sending gives an error with error message
if (e) then
  log (e)
  log (r)
-- FTP Uploader --------------------------------------------------------------------------
-- local ftp = require("socket.ftp")
-- local ltn12 = require("ltn12")
-- f, e = ftp.put{
--  host = "ftp.test.tv.tr",
--  user = "fgtest@test.tv.tr",
--  password = «ftpsifresi",
--  command = "appe",
--  argument = src,
--  source = ltn12.source.file(io.open(dst, "r"))
--Delete created file from ftp folder inside HL
os.remove(dst)
You cannot use Luasocket library for sending emails from the web server context (apps).
Attached is a modified single file version of this library: https://github.com/GUI/lua-resty-mail/
It should work from both scripts and apps. You can create a user library named mail and load it like this:
local mail = require('user.mail')
Check the link above for examples and options reference.
.lua   mail.lua (Size: 14.86 KB / Downloads: 0)
Hi , i need help for that. For test purposes , i created a simple mailtest app. In , data/mailtest i have index.lp and icon.png. In,  libs/mailtest i have mail_lib.lua ( new library you shared.) and i can't send email i get connect failure: timeout . I shared files. Can you check it out ?
.lua   mail_lib.lua (Size: 14.9 KB / Downloads: 3)
.lp   index.lp (Size: 3.86 KB / Downloads: 5)
Remove timeout = 10 from index.lp and try again.
