09.06.2026, 05:03
I'm sharing an app for Philips hue. I tested it on my own installation with a Hue v2.
I don't have many Zigbee lights and main reason was to integrate 2 ZGP devices.
Current package: philips-hue_0.3.52_all.ipk
Features
Happy to hear feedback if anyone tests it on other Hue bridge/device combinations.
philips-hue_0.3.52_all.ipk (Size: 1.04 MB / Downloads: 21)
Features
- Push-link pairing with a local Hue Bridge
- Local mDNS bridge discovery, with manual IP entry fallback
- Classic-first hybrid mode, classic-only mode, and API v2 mode
- Discovery and sync for lights, groups/rooms/zones, scenes, and control devices/sensors
- LM object creation from the app UI
- Separate command and status group addresses
- Button transformations for KNX writes: toggle, on, off, fixed value
- Optional API v2 eventstream support, with classic fallback for button handling when needed
- Install the .ipk from Apps
- Open the Hue app
- Use Discover Bridge or enter the bridge IP manually
- Press the bridge button and click Pair Bridge
- Refresh and create the LM objects you want
- Default mode is hybrid and is the safest starting point
- API v2 eventstream support is included, but in my setup it is not fully reliable yet and can create heavier system load, so hybrid/classic operation is currently the safer choice
- Tested on my own live Hue + LogicMachine setup
- License: MIT
