LM Wall Ambient Pm 2.5 Sensor
Hii Sir,
I want Add Pm2.5 sensor app. Could You Suggest Us How to Configure It Because It is not showing in LM Wall Section.
What is the serial number of your LM wall?
(11.06.2026, 06:45)admin Wrote: What is the serial number of your LM wall?
LM5FLUSH V121907P1
1. Go to System config > System > Packages
2. Remove genohm-scada-lmwall-v2
3. Install the following package:
https://dl.openrb.com/pkg/genohm-scada-l...1_imx6.ipk
https://dl.openrb.com/pkg/genohm-scada-l...1_imx6.sig
4. Install PM2.5 app. On the main apps screen click the + icon when logged in as admin. Click the menu in the top left side and select "Install from file". Enable "Allow to install package without signature" option.
https://dl.openrb.com/pkg/wall-pm25.ipk
5. Reboot LM
(11.06.2026, 07:26)admin Wrote: 1. Go to System config > System > Packages
5. Reboot LM
Thank You Sir.
