Threads: 7
What I am doing wrong?
I want to control Arcam receiver over IP and put in Command function this code:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
function tcp_arcam (
data ,
ip ,
port )
local sock ,
res ,
err
sock =
require (
'socket' ).
tcp ()
sock :
settimeout (
5 )
res ,
err =
sock :
connect (
ip ,
port or 50000 )
if res then
res ,
err =
sock :
receive (
5 )
if res ==
'PJ_OK' then
sock :
send (
'PJREQ' )
res ,
err =
sock :
receive (
5 )
if res ==
'PJACK' then
sock :
send (
data )
res ,
err =
sock :
receive (
6 )
alert (
'invalid/no ack: ' ..
tostring (
res ))
alert (
'invalid/no init: ' ..
tostring (
res ))
alert (
'connect failed: ' ..
tostring (
err ))
sock :
close ()
return res ,
err
end Then from event script using this:
cmdon =
string.char (
0x21 ,
0x01 ,
0x00 ,
0x01 ,
0xF0 ,
0x0D )
cmdoff =
string.char (
0x21 ,
0x01 ,
0x00 ,
0x00 ,
0xF0 ,
0x0D )
ip =
'192.168.11.112'
if (
event.getvalue ()==
true )
then
res ,
err =
tcp_arcam (
cmdon ,
ip )
res ,
err =
tcp_arcam (
cmdoff ,
ip )
os.sleep (
2.5 )
res ,
err =
tcp_arcam (
cmdoff ,
ip )
log (
res ,
err )
Manual of receiver is her:
Manual of control
Threads: 43
Try this:
data ,
ip ,
port )
local sock ,
res ,
err ,
len
sock =
require (
'socket' ).
tcp ()
sock :
settimeout (
1 )
res ,
err =
sock :
connect (
ip ,
port or 50000 )
if res then
sock :
send (
data )
res ,
err =
sock :
receive (
5 )
if type (
res ) ==
'string' and #
res ==
5 then
len =
res :
byte (
5 )
res ,
err =
sock :
receive (
len +
1 )
alert (
'receive failed: ' ..
tostring (
err ))
alert (
tostring (
err ))
sock :
close ()
return res ,
err
Threads: 7
(04.12.2018, 07:16) admin Wrote: Try this:
data ,
ip ,
port )
local sock ,
res ,
err ,
len
sock =
require (
'socket' ).
tcp ()
sock :
settimeout (
1 )
res ,
err =
sock :
connect (
ip ,
port or 50000 )
if res then
sock :
send (
data )
res ,
err =
sock :
receive (
5 )
if type (
res ) ==
'string' and #
res ==
5 then
len =
res :
byte (
5 )
res ,
err =
sock :
receive (
len +
1 )
alert (
tostring (
err ))
alert (
tostring (
err ))
sock :
close ()
return res ,
err
I am got nil and timeout. What you think whats wrong?
Threads: 43
Do you get any entries in alerts?
Threads: 7
(04.12.2018, 10:01) admin Wrote: Do you get any entries in alerts?
Yes receive filed: timeout
Threads: 43
Try using IR simulation commands for on/off:
cmdon =
string.char (
0x21 ,
0x01 ,
0x08 ,
0x02 ,
0x10 ,
0x7B ,
0x0D )
cmdoff =
string.char (
0x21 ,
0x01 ,
0x08 ,
0x02 ,
0x10 ,
0x7C ,
0x0D )
Threads: 7
(04.12.2018, 10:16) admin Wrote: Try using IR simulation commands for on/off:
cmdon =
string.char (
0x21 ,
0x01 ,
0x08 ,
0x02 ,
0x10 ,
0x7B ,
0x0D )
cmdoff =
string.char (
0x21 ,
0x01 ,
0x08 ,
0x02 ,
0x10 ,
0x7C ,
0x0D )
It's working.
Threads: 7
Some ideas how need to get status of Arcam in LM:
It is possible that the state of the AV may be changed as a result of user input via the front panel buttons or via the IR remote control. Any change
resulting from these inputs is relayed to the RC using the appropriate message type.
For example, if the user changed the front panel display brightness using the DISPLAY button on the front panel, a display message (defined below)
would be sent to the RC. A similar action would be taken for all other state changes (including decode mode changes).
Threads: 43
For this you will need a resident script to constantly poll status values from remote host.
